Crabbypatty
Apr 22, 2020Explorer
After lots of debate here on rv net, I went with a Pullrite auto slide as we have a short bed. My decision even though it was 8 beans more than manual was the first time i forget and put out the rear window would be way worse then paying more. 1 season on the Pullrite and it works perfectly though you need to be within 10 degrees of center or it wont uncouple. The trick is to pull the head pins and raise the fiver.
Pullrite suggests wd40 on the rails and I do that every time. Occasionally when backing up the hitch does make a grinding noise when on an angle.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
