Hello,campers i have a 16k Reese manual slider when getting in tight spots i like using it to avoid hitting my truck.My problem is when i go to disengage to slide back it will not lock into the rear ...
Is this a NEW problem....ie: worked before but now NOT locking in rearward position?
Are the lock cams inside the slider assemblies orientated in the same direction, towards the front of the truck, on both drivers side and passengers side?
See pg. 7 in link below
Are you swapping from towing to maneuvering positions when 'truck/trailer' are in a straight line?
