Hello,campers i have a 16k Reese manual slider when getting in tight spots i like using it to avoid hitting my truck.My problem is when i go to disengage to slide back it will not lock into the rear ...
Mine works great. Follow the mfg instructions. Take some of the weight off the pin by lowering the front jacks. Then move the slider handle to the slide position and move the truck forward to engage the slider pins. Then raise the front jacks and backup.
