Hello,campers i have a 16k Reese manual slider when getting in tight spots i like using it to avoid hitting my truck.My problem is when i go to disengage to slide back it will not lock into the rear ...
The slide lever on my old square tube '97 16K Reese sliding needs to be fliped quickly to the forward or maneuver position. Don't baby it. Every 6-7 years I tear it down comletely....clean it and lube it. It works so easilly I can flip the lever in fore or aft position. If the trailer is on a bit of incline it slides by itself and lock into position.
