cummins2014
Nov 07, 2017Explorer
djousma wrote:
I have a 2016 Ford F350 short box, which by the way is 6.75'. I opted to go with a slider, when I bought my Cardinal, mostly because I was new to 5th wheel towing. With that said, after 2 years of towing now, I'd still go with a slider. Let me qualify that, an AUTOMATIC slider. I went with the DEMCO 21K Hijacker autoslide, and I never have to make a determination on whether or not, I should engage the slide or not. If it's manual, as many of you have stated, it might as well be fixed, because those accidents happen at inopportune times....times when you don't think the slider is necessary.
My next truck will be an 8' bed to get the larger fuel tank, and at that time I'll switch to a fixed hitch, probably a B&W companion that fits the Ford Puck system.
I agree, no sense in buying a fixed slider, in most likelihood a mishap is going to happen unexpected, and not used to start with. If someone things they are not aware enough, or in conditions where a slider is needed, then go the automatic ,and be done.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
