TxHitchHiker's avatar
TxHitchHiker
Slider or not for 2011 F350 srw 7ft bed
Considering a different TV. Is a slider necessary for the 2011 F350 srw. I have a 2012 HitchHiket with standard pin box. Thanks in advance for your help.
    Most later model FWs with standard pin box, are actually somewhat extended. My neighbor has a HH with square front, and 6.5 bed 2012 GM truck. He has a B&W Companion non-slider. He gets pretty twisted at times, not the best at backing, but no issues with cab clearance.
    I have a non-slider in my 13 Ford SuperDuty 6' 9" bed. The pin center is 40.5 inches behind the cab. My FW does have EASY TURN, which is the rounded front cap. I keep aware, in tight turns, forward or back, but have never come close to hitting the cab.
    To answer your question, "necessary for F350", NO, but drivers ability/awareness can vary.
    Jerry
  • 4x4ord's avatar
    4x4ord
    Explorer III
    Those I know who have sliders never unlock them. I've never had or wanted a slider.
  • Depending on your weight I would consider a Sidewinder and a standard fifth wheel hitch or an Autoslider.
    Thanks!
    Jeremiah
  • Your trailer most likely was build before the radius'd front corners came along. So yes, get a slider. Chris
