d-mac1's avatar
d-mac1
Slides - How to manually close
So far (knock on wood!) no issues, but I'm wondering if there is some information somewhere about how to go about getting the slides closed on my trailer if there is some sort of problem. Anyone know?
I have 2 slides. I think the main one (living room) has a hydraulic ram but not sure. Need to know what to look for. The bedroom wardrobe slide has gears of some sort that move it in and out via little zig zaggy metal tracks on the side. Need pics??
I've called the dealer and they didn't help much and said the manufacturer has no info on it. There are no cranks that I've seen.
Dealer said on the hydraulic one, find a valve and open it and let the fluid out/pressure off and push it in. Will that really work? Its pretty dang big! What will prevent it from sliding back out when I'm hauling it down the road?
On the other one, dealer said find the motor and disconnect it and push it in. This seems possible because its a small and I could theoretically re-engage the motor to prevent it from opening back up...presuming I can access the motor.
The other suggestion from dealer was check on the internet, so here I am!
Thanks.
  • I would worry about losing your hydraulic fluid. If it does use it, find where to refill. If you drain some out, catch it in a clean container so you can pour it back in.
  • PERFECT! I now have some idea what I'm looking for. Looks like at least my big slide is a Lippert so that should crank in/out. Kinda stupid of me....I've been hauling around a crank in the basement forever and not known what its for. And never took the time to try to figure it out.
    I'll be out there this weekend figuring out exactly which of these I have and which tools will now be permanently residing in the trailer...hopefully to never be used! Fortunately, if needed, I've got an extra electric drill.
    Thanks guys!!
  • On the electric one there will be a hex nut by the motor that you turn with a ratchet usually 5/8 socket. On the hydraulic there will be what looks like a place to put a jack handle on the motor end of the hydros should be really easy to find. I think your dealers are not so smart.
