sdetweil
May 27, 2016Explorer
RedRocket204 wrote:K Charles wrote:
You just need something on the top of the door so it won't go up. Just a small piece of anything right next the roller.
Yes, something like a metal corner brace cut to size. Could be attached on the inside of the closet on each door. The part of the corner brace that would ride under the track would need to be cut no longer than the width of the door. I would put two on each door at the ends of the door. Should completely stop the door from raising.
this is why I ask for help!!.. I would NEVER have thought of this approach on my own.. I was going to edit my prior answer about some spacer above the door with 'the problem is there is over an inch gap.. hard to fill..' but this would make it easy to do..
thank you SO much..
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
