- kennethwoosterExplorerI bought a long bed truck, so took the PUllright SG out. Great hitch. While searching for a hitch I noticed B&W and Pullright should both work. Since I was getting rid of a sider I went with the B&W puck hitch. Great hitch, but sure like Pullright as well. I prefer both to the Reese. Get on line and do a search and you should find the best slider.
- CampinfanExplorer IIIDemco Hijacker
- cummins2014Explorer
bogart661 wrote:
Reese makes an adapter kit that fits into the Ford pucks and allows you to use any 5th wheel hitch that fits standard bed rails...adapter
Same setup as the new Rams, pretty slick setup if you want to use a hitch that takes conventional bed rails or the ISR series superglide automatic hitch if one wants to go that route . Everything comes out for a clean bed n7bsn wrote:
You mean the factory hitch system in current model Fords?
AFAIK it's just Reese
Pullrite offers a hitch designed to fit the pucks( mostly)... There are 2 frame brackets for the rear that need bed drilling...the front brackets go into a bracket designed to fit in the pucks...- n7bsnExplorerYou mean the factory hitch system in current model Fords?
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 24, 2026
