Greene728
Dec 31, 2017Explorer
Dayle1 wrote:
I've used 6.5 ft bed trucks for almost 30 yrs towing fivers, before rounded front caps or slider hitches. Still don't use a slider. You don't need a slider, you just need to be aware of the limitation and when necessary, do a little more jockeying back and forth in tight spots. A long bed isn't a guarantee, difference in jack knife angle is 80+ degrees to about 100 degrees. But at any of those steep angles you are twisting the trailer suspension more than moving the trailer.
If I felt unsure with a SB, I'd probably get the Sidewinder pin box. Less maintenance, weight and space, and helps with backing and tracking in turns.
Spot on! I have a SB Ram and a B&W Patriot and its great! After about 70-80 degrees your no longer backing up anyways, just jack knifing the trailer. Situational awareness and being aware of your limits is the key! I'm betting you'd be just fine.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
