Rwake901 wrote:
Who has a 6 1/2 ft bed and doesn’t use a sliding hitch? I’ve had two RV dealers and the company that makes the 5th wheel we are interested in tell me I don’t need a sliding hitch with a standard 6 1/2 ft bed.  But when I go to Curt’s website (the maker of the hitch) they tell me I do need a sliding hitch. (Plus I emailed them)  Who do I believe? I’ve read some other posts where people say they have one but never use it. Thanks for the help.
   Curts website doesn't know what your trailers front corner profile looks like and others that don't know will say get a sliding hitch.
 Pay close attention to Dayle1 reply in his first paragraph where he says:
You don't need a slider if you can remember to pay attention. But as already stated some of that depends on the variables. Bed length is not an issue. Cab-to-axle (CA) distance is , GM is the longest, Ford just a little less and Ram is the shortest. Then fiver cap design is the other big factor.***
 Many GM owners with the newer rounded/notched front corner profile don't need a sliding hitch at any angle mainly because of that longer C/A (back of the trucks cab to the trucks rear axle). Also installing the hitch with the pin zero over the rear axle helps also. The last 3 trucks I've owned were crew cab short beds and always have my pins zero over the axle.
 The larger RV dealers who carry several hitch brands and installation can help you there.
  Others like myself have a Dodge with a 6' 4" bed and pull a older '97 30' 5th wheel trailer with flat square front corners. Sure I need a sliding hitch but its seldom used.
 I have found that backing with the hitch slid back all the way places the pin 10"-11" behind the trucks rear axle.....this causes the trailer to react quicker with less steering input while backing in a really tight/twisty situation.
