- After experiencing the smell of propane intermittently for several months and soaping every connection and regulator I finally found my leak. On top of the tank where the valve threads into the tank I got slight bubbles with a soapy solution. Very slight but of course it does not take much of a leak to smell propane. I took the tank to a company who sells propane and they were authorized to replace the valve with a new one. Apparently the threads on the valve had been damaged somewhat and this prevented it from sealing good. You could actually see damage to the threads. Now I have no more leaks!!
djousma wrote:
Not normal, however Propane gas is heavier than air, and is why, I assume that the "floor" of my LP tank compartments are open mesh to let any excess gas escape. I dont know if all enclosed LP compartments are made that way, but I'd almost guess its a requirement for this very reason.
Yes it is and also it's required that no locks are on the doors of the LP tanks so anyone can open and turn off the propane in an emergency- MikeRPExplorerFolks::
Never ignore the smell of propane under any conditions. Someone noticed a leak on Rockwood Roo years ago. If he hadn’t said anything, it may have killed me and my family. I got where I close the tanks every night before bed.
Also had another incident that a newly replaced alarm in the camper caught a valve on the stove that was hit by my son that was just ever so leaking while we were sleeping. Super dangerous.
You are doing the right stuff, keep at it till you get it fixed.
Peace. - Edd505ExplorerCheck the pig tails I have replaced two sets in 2.5 years, the rubber drys and cracks. The last ones I had made at a propane dealer. They had rolls of hose and boxes of fittings.
- mtofell1ExplorerI'm going to disagree with the masses on this one. There is a vent on the underside of the switch and it's not uncommon to get some smells from that. If you can't find anything from a soap test and your tanks aren't going empty sitting with the valves open for prolonged periods I wouldn't worry about it.
- Curly2001Explorer IIJust went through the same thing and it is the regulator. Also did the hoses just to make sure due to the age of the unit. The cost was small compared to the damage it could do.
Curly - BB_TXNomadI should have said a high pressure propane regulator IN ADDITION TO the dual auto switch over regulator. It is the small high pressure regulator that is known to leak.
- Dave_H_MExplorer IIgood info there BB :C
- BB_TXNomadIf you have a high pressure propane regulator (not the dual auto switchover regulator) it may well be that regulator that is leaking. A not uncommon problem. But the relief hole is probably on the bottom side and hard to get soapy water on it to check for leaks.
I had the same slight but continuous odor several years ago. After thoroughly checking all connections, hoses, and regulators with soapy water and finding no bubbles, I finally replaced the high pressure regulator valve after reading a number of posts about them failing. After removing the regulator I could see that there was an oily residue around the small hole on the bottom. With the new regulator I have never had propane odor again. - LwiddisNavigator“This was one of my draw backs for fifth wheel trailers... My two propane tanks are directly under my front bed overhang haha.”
But on most TTs the propane tanks are 12 inches from your sleeping head.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
