sgolembiewski09's avatar
Aug 27, 2019
Slight smell where the LP Gas cylinders are located normal?
My fifth wheel is parked right now. When I close the tank valves there is no smell, but when I open them there is a slight propane smell. It is present all the time and not overwhelming. I read about pressure relief valves... any thoughts on the topic? Do most people with 5th wheels experience a constant "slight-smell"?
  • Be sure to turn the tank valves completely open till they are tight to prevent leaking around the valve shaft.
  • Make sure you get some soapy water on the breather port at the bottom of the regulator. I'll bet the diaphragm is failing. No it is not normal, you should never smell Propane unless you disconnect a line..
  • You should spray all connections/fittings with soapy solution and look for signs of leaking (bubbles) WITH the cylinder valves OPEN
    Spray the valve
    Spray the Large Green ACME Nut
    Spray the area behind the Nut where hose connects
    Spray the LP regulator....crimped body, hose fittings, vent holes (small pin hole pin 1st stage and 1/2" screened vent on 2nd stage)
    We would get a slight whiff after having cylinders filled....propane residue from bleeder valve.
    Otherwise......NO
