Old-Biscuit
Aug 26, 2019Explorer III
You should spray all connections/fittings with soapy solution and look for signs of leaking (bubbles) WITH the cylinder valves OPEN
Spray the valve
Spray the Large Green ACME Nut
Spray the area behind the Nut where hose connects
Spray the LP regulator....crimped body, hose fittings, vent holes (small pin hole pin 1st stage and 1/2" screened vent on 2nd stage)
We would get a slight whiff after having cylinders filled....propane residue from bleeder valve.
Otherwise......NO
Spray the valve
Otherwise......NO
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
