cummins2014's avatar
cummins2014
Slow leak
I have lost 25 lbs of air pressure in one tire in the past 6 weeks or so sitting in the driveway . Turned on the TPMS to check for the upcoming trip , and three were 102 psi. , the low tire was 77. I raised the tire and rotated, nothing visible I can see . I sprayed soapy water on the valve stem , couldn’t see anything there . Can’t see any visible cracks in the wheel . I’m losing less then 1 psi per day . Only thing I can think of doing at this point with such a slow leak is replace the metal valve stem .l did tweak the nut a little tighter on the valve stem to see if that helps . Any thoughts where the air loss could be ?
  • Could be a leak in the valve stem. I had a slow leak in RV tire and at another time my truck and in both cases it was a leak at the valve.
  • Michelle.S wrote:
    Do you or someone near you have a Kiddy pool that you could put the tire/wheel into?? I had a slow leak in a brand new unit and couldn't find it, took it to a tire shop and they put it in their dunk tank and found a pin hole in the Rim it's self.
    I'll add this to my above post.
    In addition to that pin hole in the rim when brand new, I had a second wheel develop a slow leak, it too turned out to be a pin hole in the rim, but took three years before it showed up.
  • IB853347201 wrote:
    Spend $15 and have the rim cleaned, the tire remounted and sealed at a local tire shop. I would never head out with a tire that is leaking. Just an accident waiting to happen.
    Yes my concern also, leaving on a trip in a week . I will get it off tomorrow ,and get it to a tire shop .
  • Diamond c wrote:
    You didn’t say but I would air it up to at least 110 psi then put the weight down on it and then start soaping it down good.Take your time and watch very close.
    I did air it up to 110 psi, and did the soaping just around the valve stem. Nothing I could see. At this point I may take it off, and have it checked out . I am just afraid at less then a psi a day, its going to be tough to find. I can live with what its doing, but my concern is its going to go bad in a hurry , like someone mentioned ,a possible cracked rim. Also mentioned corrosion , I see a bit of discoloration on the valve stem down at the rim, a bit different then the rest.
    These wheels are less then two years old. They have never had any air loss until about six weeks ago. They actually sat all winter ,without a problem., no air loss in any of them .Took it on a trip to Arizona , sat in a RV park for a couple weeks ,when I turned on the TPMS ,that one tire was down about 5-6 psi , and now as said been sitting again for the past six weeks ,and was down 25 psi. So It developed this leak on the 500 miles to Arizona . No issues prior to this trip.
    Thanks for all the replies, I will eventually get to the bottom of it hopefully, could be one of the things mentioned here .
  • Spend $15 and have the rim cleaned, the tire remounted and sealed at a local tire shop. I would never head out with a tire that is leaking. Just an accident waiting to happen.
  • Aluminum rims can corrode. That ended up being the reason the first two tire shops I went to couldn’t find the leak.
  • Do you or someone near you have a Kiddy pool that you could put the tire/wheel into?? I had a slow leak in a brand new unit and couldn't find it, took it to a tire shop and they put it in their dunk tank and found a pin hole in the Rim it's self.
  • Had a similar issue in a car tire. Lost 10 pounds over three months. Every three months. Nobody could find it. Had the tire removed so I could spray the interior part of the rim with urethane in case it was porous. Took off the valve stem -metal with a tpms sensor- and found a very fine corrosion line going between the wheel and the rubber part of the valve. Cleaned the valve and rim and put it back together without spraying. Four years and no air loss. We had lived where a lot of salt was used. Now the only salt is on the food. Annual average snowfall went from 93 inches to .05 inches a year.
  • You didn’t say but I would air it up to at least 110 psi then put the weight down on it and then start soaping it down good.Take your time and watch very close.
