scotty46's avatar
scotty46
slow toilet leak
It seems that the inside of the toilet bowl has a very slow leak. Is it a big deal to replace the rubber seal or is it best to take to the dealer?
  • I second the motion for using silicone grease. Just make sure the seal and the knife blade are dry before applying a liberal amount of silicone grease to both. I have used this method for years and it saves a lot of work and expense.
  • Last time I looked the seal was around $10. Not hard to replace, just look at your toilet's owner's manual for directions. If its a decent quality dometic thats in good shape otherwise its usually worth the time to fix. If its an old plastic creaking special I always upgrade to a 310 or 320 model. Walmart sells the 310 for $199.99.
  • As said, a thorough cleaning is a good start. I've also used vinegar to flush as per a suggestion on here. It seemed to help,
  • I've yet to master the revitalization of flush ball seals, always had to replace them especially when the kids didn't understand the concept of keeping water in the bowl.
  • Before replacing clean the seal and lube it with plumbers silicone grease.. Don't use anything petroleum based!
