cummins2014's avatar
cummins2014
Slow leak
I have lost 25 lbs of air pressure in one tire in the past 6 weeks or so sitting in the driveway . Turned on the TPMS to check for the upcoming trip , and three were 102 psi. , the low tire was 77. I raised the tire and rotated, nothing visible I can see . I sprayed soapy water on the valve stem , couldn’t see anything there . Can’t see any visible cracks in the wheel . I’m losing less then 1 psi per day . Only thing I can think of doing at this point with such a slow leak is replace the metal valve stem .l did tweak the nut a little tighter on the valve stem to see if that helps . Any thoughts where the air loss could be ?
