kaydeejay wrote:
BFL13 wrote:
"Payload" is not the same as "Cargo" with Chevs, at least in 2003.
"Cargo" is with full fuel but maybe not "Payload". My truck GCWR is 9,200 and the CWR and ("T" on the label) is 2,770 (what is allowed in the box) It is a five pax for 150 each for 750 so "Payload" is 750 + 2770 = 3,520 which would be on the stickers that came out a few years later for "cargo and passengers" limit.
However the 2003 brochure says its "Payload" is 3,643.
So maybe the 3643-3520 = 123 is gasoline, but 128 litres must weigh at least twice that.
So it is not altogether clear.
Is that five passengers PLUS driver, or 5 occupants total? If the latter, there is the rest of your fuel.
Also, that "brochure" weight is a typical weight for 2500HDs, not necessarily the exact number for your truck.
This is directly from the NHTSA document. There is no reference to the weight of fuel in the calculation. Waste of time using the weight of fuel.
Steps for Determining Correct Load Limit
1) Locate the statement "The combined weight of occupants and cargo should never exceed XXX kg or XXX pounds" on your vehicle?s placard.
2) Determine the combined weight of the driver and passengers that will be riding in your vehicle.
3) Subtract the combined weight of the driver and passengers from XXX kilograms or XXX pounds.
4) The resulting figure equals the available amount of cargo and luggage load capacity.?For example, if the "XXX" amount equals 1400 lbs. and there will be five - 150 lb passengers in your vehicle, the amount of available cargo and luggage load capacity is 650 lbs. (1400 - 750 (5 x 150) = 650 lbs.)
5) Determine the combined weight of luggage and cargo being loaded on the vehicle.?That weight may not safely exceed the available cargo and luggage load capacity calculated in Step 4.
6) If your vehicle will be towing a trailer, load from your trailer will be transferred to your vehicle.? Consult this manual to determine how this may reduce the available cargo and luggage load capacity of your vehicle."
