schlep1967
Aug 11, 2020Nomad
Drain and refill a few times. Really no need for bleach. Doesn't matter if you have an anode rod or not. It all depends on the source of water used to last fill the water heater.
I know my home well water does not cause the smell. Some campgrounds we visit and use there water supply it will smell if left in the water heater. Simple fix for me is drain the water heater when I get home. No anode for my water heater so I plumbed a valve in place of the plug. Makes draining easy. Just make sure you refill it before the wife turns on the water heater the next time you go out...
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
