Linedog's avatar
Linedog
So I weighed my Fiver.
Same scale used both times, only difference was about 15-20 gallons of gas.
Empty truck weights,
Front axle, 3140
Rear axle, 4100
Total 7,240
Truck with the fiver,
Front axle, 4260
Rear axle, 5060
Fivers axles, 7560
Total 16,880
So am I to assume my fiver weighs 9,640 pounds?
  • Yep, you need to weigh it again. Truck front axle should change less than 100 lbs., so that is a problem. And the difference in rear axle is only about 900 lbs which is TOO low for a realistic pin weight.
  • Nope no typo. I'm taking the truck threw one more time to be sure.
  • Is there a typo for the Truck with fiver front axle? Seams like it should be 3260 and not 4260.
