rskeans
Feb 21, 2015Explorer
Me Again wrote:
What he was saying that if you break down someone (the majority) can not tow your trailer for you without removing the Anderson coupler and you can not tow someone else trailer with added your coupler to it. Conventional 5th wheel hitches interchange between all makes (except sliders) including semi trucks!
Oh. OK.
I guess that you are referring to the adapter block that secures to the King Pin? If that is the case, It takes less than 3 minutes to remove it. i.e. You'll need a 1/4" allen and a 15/16 box or open end. Release the tension on the (4) 1/4" allen screws, then remove the two 15/16" bolts that go around the neck of the King Pin. That's it.
I think we are making a big deal out of nothing.
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
