kohai
Mar 03, 2015Explorer
psuce wrote:
My question on the Anderson gooseneck to fifth wheel adapter is can the Anderson hitch be flipped front to back? Looking at pics of it, when you install it the hitch base is centered 5-6" behind your gooseneck ball. Then when you add the kingpin adapter you're another 5-6" behind that, so when it's all said and done the king pin is now 10-12" behind center of axle (assuming your gooseneck is installed within centerline of your axle). In my long bed I would rather be centered, does anyone know if this can be accommodated on the Anderson? Here is a pic for reference:
You can mount the aluminum block on the kingpin the other way around so that the ball socket is behind the kingpin instead of in front of it (your pic). That is what I do, otherwise I risk the back of the pinbox hitting the side bed on a sharp turn.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
