Cummins12V98
Mar 03, 2015Explorer III
psuce wrote:Me Again wrote:
Strap(mount to a jig similar to truck bed) the two hitches pictured above down(Anderson resting on bed and B&W frame mounted) and set the press to push forward and backwards on them and see what happens. Chris
Technically the B&W Companion gooseneck to fifth wheel sits on the bed the same way the Anderson does. The B&W pictured above is the puck mounted version. Below is a picture of the B&W gooseneck to fifth wheel for reference.
Yes and B&W stepped up and are using a spacer now so the hitch base does not push fore and aft and deflect the truck bed as I guarantee you the Andersen does with a larger RV.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
