Cummins12V98
Mar 03, 2015Explorer III
psuce wrote:Me Again wrote:
I think we can "maybe" all agree that with large heavy trailers having the pickup bed carry the weight verses the truck frame is a compromise that one agrees to with either the Anderson or the B&W Companion! Note: Beds are corrugated sheet metal and not the strongest part of the truck!!!!
Actually the gooseneck hitch will bear the vertical weight of either the Anderson or B&W, as most styles of gooseneck are mounted directly under the bed corrugations and onto the truck frame. Most goosenecks also have a vertical load rating of between 6,000 and 7,500lbs, a lot more than the pin weight of most fifth wheels. This is just the gooseneck hitch, not the added load carrying capacity of the bed itself.
Think about the weight that is applied when the brakes are hit hard and winging over some of these overpasses the hitch IS pushing fore and aft and it will and does deflect the bed. I have dents to prove it in the 11 I just traded. Once I installed the strips the deflection stopped!
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
