Cummins12V98
Mar 05, 2015Explorer III
rskeans wrote:Cummins12V98 wrote:RustyJC wrote:up2nogood wrote:
I'm curious, would you tow your new fifth wheel with your old B&W, and gooseneck connection ,instead of the new B&W connected to the four points on the OEM fifth wheel prep, and if not what would be the reason.. Is it not rated for 25K .
In fact, I DO tow our Mobile Suites 38RSSA with the gooseneck-connected B&W Companion RVK3500. My hitch is rated for 20K total trailer weight and 5K pin weight and handles the 19K GVWR Mobile Suites very well.
B&W Companion
Rusty
I towed our 20K MS with the same hitch as you Rusty. Still IMHO even this is a far superior hitch to the Andersen.
The B&W has solid strips under the bottom base to fill in the low part of the corrugation so the base transfers weight to the bed cross members then to the frame when the RV forces the hitch to flex in the fore and aft directions. The hitch in pic is only rated for 18K. Since they have redesigned the base for 20K. I admit I was 2K over the rating but the wife kept adding weight so I bought a new truck and installed a hitch rated for 25K as shown several posts up.
In looking at your pictures I see why B&W had to provide the solid strips under the bottom base. Your hitch is just sitting on two parallel rails. The Andersen is sitting on a square support base. Any fore/aft forces on the Andersen is distributed over the cross section that goes across the bed. B&W doesn't have that. B&W is just making up for a design deficentcy. That's OK. They acknowledged it and provided a fix.
Now, I would like you to explain why the B&W is such a 'far superior' hitch.
Not trying to be rude here but that thin pc of metal is only designed to keep the "Pyramid" from collapsing and has zero benefit keeping the hitch from deflecting the bed!
I have eyes that is how IMHO the B&W is a Superior product. Not sure why all you Andersen guys get so defensive???
I am just giving my "OPINION" !
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
