rdmotex3
Dec 07, 2020Explorer
So Lost
Hello all I have read,and read, and read but it seems you can slice the argument whatever way fits your setup best. I just signed docs on a Reflection 367 and am waiting to set up an appointment for t...
JIMNLIN wrote:Op says his door sticker states just over 2200 lbs of capacity. Old biscuit wrote the 5ers wet pin is/should be 3200 lbs. My guess the truck itself weighs around (don't recall seeing OP's set up) 8500. If that's the case, legally only has 1500 lb avail for extra being it's a 10,000 GVW truck. So assume for a moment we use OB's numbers along w/ an assumed truck weight. 8500 + 3200 = 11,700 which according to my fingers and tows puts him over the trucks GVW by 1,700 lbs. Shoot, that's actually over a 350's GVW of 11,500 by 200#.
The truck makers GVWR or a GVWR based payload or the GVWR payload sticker isn't used to determine a overloaded truck. Nor do we face lawsuits for exceeding the truck makers GVWR.
Lawsuits regarding exceeding the mfg GVWR....RV internet myth. It doesn't happen on the commercial side so why is it just someone pulling their rv trailer that faces law suits for exceeding a GVWR.
Any theories why ??
Having pulled commercially with LDT size trucks civil lawsuits do happen to those in this line of work that our overloaded truck/trailer caused a accident...but the vehicles GVWR isn't used to determine that overload condition.
