Old-Biscuit wrote:
2020 F-250 King Ranch 6.7 diesel
RAWR....6340#
2020 Reflection 367
GVWR ....14495#
22% for WET PIN....3200#
You will be over the trucks GVWR but under/right at the trucks RAWR/Tire Load Rating
THOSE are the weight ratings you need to be concerned with
**can control RV weight by NOT Loading it up to MAX GVWR
Load truck up now 'Camp Ready' ... you/All passengers/any-all 'stuff' (bags, back packs, containers etc) and HITCH
Go to a CAT Scale and get weighed... $12/15
Then you will have ACTUAL Truck Numbers to work with
rdmotex3 wrote:
So here's where I get lost.The sticker in the door says 2214? That mean I'm not even close. As I understand it my set up with a 3.31 axle could tow 14,100 but because of the pin weight of ~3,000# I would be over before I ever put it in drive? Sorry to be the noob here but it all makes my head hurt.
Well what Old-Biscuit suggest can put you in legal limbo if involved in an accident. While many will argue that GVWR has no legal status, read the towing section of your owners manual. It will state several times it is not safe to exceed and of the weights on your VIN sticker (NOT YELLOW STICKER). A good lawyer will seek to assign part or all blame to you in a civil suit. We live in a
"It's Not My Fault" society. So even if some jerk pulled out in front of you you could end up paying.
Even if you do as suggested you are going to likely be over or very close to that rear GAWR. Your empty rear axle is likely to weigh 3,000 to 3,200#, leaving about 3,000# to 3,200#, but you still need a hitch, and DW?, kids, tools?
That 5er only has a 2,521# listed payload capacity, and is 41' long, not much payload for a long 5er.
I am sorry to say you have a very plush grocery highway cruiser.
Good luck with what ever decision you make.
