bandit86
Aug 03, 2015Explorer
soft floor, depression under bike wheel, oil guard?
Just finished the second half of my 3000 mile trip. All the way down there no problems, no issues noted. Left my toy hauler parked in Houston for 1 month. second day driving back, we noticed the rear bed at the right rear corner is sagging, the floor is soft under the bracket. Ended up ripping right out of the wall. While looking at it my son noticed the spot 2 feet away, where my bike's rear wheel was (front in wide choke) is depressed too. Could it be heat related, or heat/ pressure from bike strapped down? I can't explain the middle of the rear floor sagging. The bed bracket I know there is some new caulking on the roof it probably leaked and PO fixed it. Maybe it was bad I never noticed it.
He did oil guard the bottom of the camper, could the oil seeped into the wood and cause the sag? I'm tempted to try some penetrating epoxy I read about in a boat forum. I think it's epoxy and acetone mix, holes drilled every 4 inches and the epoxy will migrate through the wood. If i can get through this summer I can worry about it in winter time
