okan-star
Mar 19, 2015Explorer
smkettner wrote:clotus wrote:
Do you guys think I should go with a PWM charger, or spend the money now for a MPPT charger? I am looking for a good 3-stage charger that I can adjust the charge voltage. I like the idea of the bogart controller. I was also looking at the Blue Sky and Mourning Star chargers. I want to spend the money now as opposed upgrading later.
Read the Bogart manual for available settings but I think it will do everything you need. My perception is Morningstar is a level up vs. Blue Sky if you choose one of these.
With just two batteries and around 300 watts of 12v panels you will have plenty of power. I see MPPT for larger systems with 24v panels, 4+ batteries, large inverter etc. The MPPT does not extract as much extra as they would have you believe. Most claim 30% boost but that is only when the battery is super low. During most of the charging time the boost is closer to 5% as bulk ends and 0% during absorption.
The 30% they claim is just a estimate , if you charge at 14.4 volts 30% of that is 4.32 + 14.4 is 18.72 which is a normal range of panels
It depends on what type of battery you have your controller set to charge at and at what level of charge its in , bulk, absorption , float, equalize , that would determine the diff between a PWM and a MPPT , the MPPT uses all available voltage in bulk stage ,in the others its likely to be using more most times as well , its capable of it , it depend on the battery state and what it requires at the given time
I have 4 interstate 6 volt GC2 232 amp hr battery's that require 13.6 in bulk , 14.4 in absorb ,13.7 in float , 15.10 in equ
The Morningstar Tristar MPPT TS-RM-2 remote panel does every function you need and shows battery states at all levels , amp hrs , amp hrs used , watts , watts used ....
I have a PWM on my TC and its fine , its a mater of cost per system , what you need per system and how much you want to get per dollar you spend , if you use a PWM and think later you might change to a MPPT be sure you can use the wireing and breakers .... or your going to spend more in the long run doing it twice
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 19, 2026
