The pre wiring is not actually much of a deal. I believe it's just wires in the hallway wall that drop down to the basement. The charge controller in that case would mount on the wall in the hallway and wires would be drilled up to the roof top through the top plate. This prewiring going down to the basement is not heavy enough to run any kind of amperage.
I think I'm going to use 8 gauge wire (possibly even 6 gauge just because I have a piece kicking around) from the roof top down to the basement where I will mount the charge controller. I haven't looked it over close yet to determine where I will run the wire but I might pull that same wall panel off and drill up through the top plate to the roof and then down though the bottom plate into the basement.
