wademartin's avatar
wademartin
Solar system advise needed
I want to install a solar system in my 28 foot Gulfstream Innsbruck 5th wheel camper. I will be operating the furnace, hot water heater, stove and refrigerator on LP gas. I need to install an inverter to keep batteries charged and to operate a TV, satellite receiver, radio, and computer. Suggestions on what size solar panels , roof mounted or portable, what size inverter, and battery bank will be appreciated.
Thanks
  • pianotuna wrote:
    Hi Roy,
    Do you really mean 3000 watts (or is it 300 watt)? Yes, 3000 watts
    Do you really mean Gel cells, or do you mean AGM. No, I meant AGM.
    Gel are unsuitable for a 3000 watt inverter, running flat out, and could be permanently damaged by a 300 amp load.
    AGM would tolerate the load (but probably not like it).
    The entertainment center would be happier with a pure sine wave inverter, but since you have it, you could try it.
    Is the battery bank wired in a balanced manner? Please clarify.
    roy67ss wrote:
    This will be a DIY install. Looks like I will go 12v.
    I should probably elaborate a little. I have a cheapo 3000watt inverter ( Can.Tire ) PD9260 convertor, 2 - 12v 110ah gel cell batteries and intend to run only the entertainment center with the inverter. The 110v units are the TV and the sat receiver but would also be recharging the 2 laptops from there. I am good with the rest of the house running on 12v and propane.
    Every 12v light in my unit is led.
  • roy67ss wrote:
    pianotuna wrote:
    Hi Roy,
    This is what is balanced and best for twin twelve volt batteries.
    As it often doesn't cost a dime more to do this, I think it is worth the trouble.
    If you wish to understand the "why" surf here:
    correctly interconnecting multiple twelve volt batteries
    Others may say it doesn't matter--but unless there is a compelling reason to not optimize charging and discharging why not do it the best possible way?
    Here is a video of 3 twelve volt batteries that have been wired in an unbalanced manner for 2 years. They have been equalized. The test shows how CCA has been adversely affected.
    unbalanced for 2 years
  • Thanks, I have been using that method for many years when dealing with 2 or more batteries.
