fj12ryder
Sep 10, 2022Explorer III
GIB2 wrote:Yeah, you found it worked for you, but I have no desire to go that route. There are choices, thank you very much. Yours isn't the only one that works.
To Fj12ryder :
"Oh Bosh" doesn't make you right and me wrong.
I bought a brand new Montana fifth-wheel. I took it from Buffalo NY to Florida and back and I also took it from Buffalo to California and back. On the way home it was dog tracking so badly I stopped to see if something was broken. I brought it home and had a local manufacturer make a new axle of 250 thousandths wall thickness. The original was a Dexter 188 thousandths thick. At same time I put brass bushings and wet bolt kits. I took it to Florida and with a high pressure grease gun couldn't get grease into them and that axle was bent. At that point I made an appointment with Mor/yde and had the problem corrected properly and installed Disc brakes. I will change my wording . Everything prior to Mor/yde was a band-aid and pissing into the wind.
PS:I also had an extra leaf added to each left spring and it still didn't sit right. AGAIN Mor/yde
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
