OutdoorPhotogra's avatar
Aug 06, 2017
Soon to be 5th Wheel owner
We had a pop-up for 7 years and loved it. I gave it to a family member last year because it couldn't handle the mileage we put on it with long trips and moves. It's been hard not having a camper, particularly now that I'm in AZ with so much boondocking available on public land.
I will soon purchase a Rockwood 8288SS from a family member. Not sure of exact year but it's around a 2008. I can't wait to be back in the game.
I'm new to 5'ers. 30 years ago I towed a 26' flat bed gooseneck occasionally for work and loved it compared to bumper pull. I'll need to find a place to practice the difference in backing response.
I'm looking at a B&W companion hitch. I don't need that much capacity with a 9,000 lb 5er but I like that I have a flat bed when I remove it compared to the patriot hitch. Is it possible for the hitch to be overrated for 5er weight?
TV is a 2012 F-250, 6.2 with 3.73 axle. Truck weighs 7160 lbs with full tank of gas. 10k lbs GVWR.
I look forward to hanging out on this forum more as well as boondocking. Time to research battery banks and inverters.
  • Thanks for the reply. Yep, I prefer to have several thousand cargo capacity but I can make it work for 5 years. I would have preferred a TT to keep my bed for extra storage but I do like the simplicity of hooking up a 5er. This is a good deal for family member to sell and gets me back camping sooner.
    I've put my truck on scales multiple times. 5vr is located several states away so I won't be able to put it on scales to get a true dry weight for a while. Battery bank could be an issue with weight.
    We've camped across the U.S. twice on moves but this will mostly be used for long weekends where packing light is easy.
  • 2008 Rockwood 8288SS
    GVWR ......8461#
    VWR ......6932#
    Dry pin weight.....1461# with 5471# on axles (a 21% dry pin weight)
    So load up 5vr with 1500# of stuff (water, propane and your stuff) you will be very close to 5vrs GVWR and have a Wet pin weight close to 1800#
    Could overload 5vr easily BUT should have NO problems with weight on truck
    And truck S/B able to easily handle that 5vr.
    Just remember....
    Any extra 'options/upgrades' added to 5vr cuts down on what you can load for camping,,,,,,,,,clothes, linens, pot/pans, FOOD, pantry, etc.
    Only have 1529# of CCC for 5vr. (GVWR minus DRY weight)
  • A pop-up "...couldn't handle the mileage we put on it with long trips and moves." Interesting.
