hobbicam's avatar
hobbicam
spanking new.. problems..
Hope this is not the start of how this will go..
Picked up my 2014 LivinLite VRV toyhauler.. earlier this month, but due to the cold, the dealer had told me that it was already winterized so we did not get a chance to test much out. He told me that this coming spring, I can swing by and he can help me test it and unwinterized it. so that is the plan for the plumbing part.
Now, today we had some good weather up in the 50s.. sunny and it was a nice day to get out and play around with all the electricals.. I plugged the livinlite to shore power, tested the propane "furnace, stove top.. all seems to work.
I then went to turn on the Domestic brand (2 door) re-fridge and got an E3 error. From the manual it reads "The cooling unit has malfunctioned. Contact a Service Center"
now, off to email my dealer. I found another posting somewhere that had some bad stories on their unit. I hope I won't be singing the same song, just a different verse of it.
Arrrggg.
hobbicam..
  • sportsman 500 wrote:
    And don't operate fridge off level........it will cause damage.
    I am confused by that statement. These refrigerators are designed to be on while driving down the road. Hardly a level environment while doing that.
    bouncing around driving down the road sort of negates the need to have it plumb level.
    bumpy
  • RoyB's avatar
    RoyB
    Explorer III
    Whenever I first try to use my propane I always light off the stove top burners to purge the propane lines... Sometimes my furnace won't lit off the first couple of times if I don't purge the lines first.
    Roy Ken
  • And don't operate fridge off level........it will cause damage.
  • othertonka wrote:
    The refer needs 12 volts DC, battery power, along with the propane in order for it to work. Make sure the propane is ON at the tank and that you light the stove burner first and let it burn until it burns steady, this will get the air out of the line, .
    yep, how long//many times did you wait to try to get the refer to work. might take several tries initially as you say to purge the lines.
    bumpy
  • Got the new rig and doing a little 'driveway camping' I take it??
    Would you happen to have leveled the rig before trying to run the fridge??
    There is a reset located on the left side of the fridge inside the lower outside vent. It is between a couple wires and hard to find. Push the tiny button back in and reset the thermal device.
  • The refer needs 12 volts DC, battery power, along with the propane in order for it to work. Make sure the propane is ON at the tank and that you light the stove burner first and let it burn until it burns steady, this will get the air out of the line, Then make sure the battery is fully charged, 12.6 volts, and that the battery disconnect switch is in the ON position then turn the refer to GAS and you should hear the igniter try and light the refer. It might be best to disconnect from shore power while doing this test so you are just testing the gas part of the refer. If you have the refer on AUTO and plugged into shore power, it will automatically switch to 120 V AC and you wont hear any noise indicating that it is working because it is silent in operating on shore power. Give it a try and let us know what happens.
  • First, congratulations on your new Livin' Lite- my dream trailer! It's rough to have any problems at all with a new rig, so sure understand your concern there...but if it's any comfort, this problem isn't related to its construction, so no worries there, right?
    The "E3" error code on a Dometic may be a real simple fix. I THINK there's a red "reset" button on the back of that fridge. If it's there, it may need to be reset....
    If that doesn't work, I'm sure others will have suggestions- and if NOTHING works, I'm betting that Camplite will step right up, even though appliances are usually covered by their various mfr's. They have a very good customer service rep, and want to keep it.
    Good luck!
