4WD allows you to get further from the road before you get good & stuck, at which point you call a tow truck which is likely to be 2WD.
If he can't come & get you the debate now becomes, winch or no winch.
A driver has to know his limitations.
I'd like to have a locking diff. Chances are that if stuck with the trailer on the back there won't be much weight on the front of the truck to help. I know, locking diff makes the vehicle want to go straight. Thats OK. Rather have 2 power wheels under the weight.
Got stuck in a mucky CG this year with the trailer on. Managed to get the rear wheels onto boards that are used for leveling the trailer then proceeded to work my way forward one board length at a time. Got myself to about 1 board length to solid ground. That is when the CG tractor showed up with a chain. Oh well!
4WD would not have helped much there. The whole area was snott slippery.
