laknox wrote:
fj12ryder wrote:
We use our truck almost exclusively for towing our toyhauler, which we don't take offroad. It pretty much sits from mid November to around April so we don't worry about the snow. Our other truck is 2WD and it gets driven year round. I've owned 4WD in the past just for the heck of it and have just come to the conclusion that, for me, it's an unnecessary expense and complication. KISS.
The thing that always amazed me was when I was traveling during and after the winter storms around here, that most of the vehicles in the median were 4X4's.
Most of that is the fact that people simply don't know how to drive in weather and they'd've ended up in the ditch either way. I saw this several years ago driving on I-40 up on the Navajo Rez. Was a freezing fog and it was coating the freeway pretty good in spots. I was in my Civic and driving about 35-40 mph with my flashers going. A number of cars passed us doing 50-60. Several miles down the road, they were all balled up along the side of the road, including a 4wd Tahoe. Idiots...
Lyle
X2 to People don't know how to drive in Snow and ice!
Now days Sales persons and Advertising showing those with AWD and 4X4 ripping around very fast and supposedly in control. This is why when it is bad out those people believe that AWD and 4X4 think they can drive the speed limit without issue.:S
Veebyes wrote:
4WD allows you to get further from the road before you get good & stuck, at which point you call a tow truck which is likely to be 2WD.
If he can't come & get you the debate now becomes, winch or no winch.
A driver has to know his limitations.
I'd like to have a locking diff. Chances are that if stuck with the trailer on the back there won't be much weight on the front of the truck to help. I know, locking diff makes the vehicle want to go straight. Thats OK. Rather have 2 power wheels under the weight.
Got stuck in a mucky CG this year with the trailer on. Managed to get the rear wheels onto boards that are used for leveling the trailer then proceeded to work my way forward one board length at a time. Got myself to about 1 board length to solid ground. That is when the CG tractor showed up with a chain. Oh well!
4WD would not have helped much there. The whole area was snott slippery.
Yep, just like following a GPS up a logging road thinking it is a short cut to the freeway! :S
In your case four wheels pulling would likely gotten you out if you didn't stomp the throttle.
The trip below, I was in 4X2 until about halfway up the first big climb on Highway 26, then the rear tires broke loose, Dropped into 4X4, and continued home, otherwise would been ion side of road chaining up!!!
We also needed to come to a complete stop on an uphill grade for the State Patrol to clear a spin-out into a guard rail, no issues getting going.
When I was younger i was a Boy Scout, the be prepared stuck!
It is still personal choice!!:)
