klr650goldwing
Jan 21, 2019Explorer
SRW vs DRW
Is there a general rule regarding how much weight is okay for SRW and how much is too much? We are thinking of a larger 5er and not sure how much larger will require a new truck too.
rhagfo wrote:
Just have to ask, how does that 5er tow/ride with less than 15% pin weight?? I would think it would be a bit of a bucking bronco.
Charlie_on_lake_conr wrote:
Hi, brand new member looking for confirmation from the experts (lot’s of good discussion in this topic) and I don’t want to trust the salesman. I’ve poured through the owners manuals and towing guides and have calculated a trailer GVWR of 18,454 based on my TV (I know I need to actually weigh my TV, but let’s assume my base numbers are correct).
First question - does this TT GVWR sound right?
Second question - Would a 5th wheel with a UVW of 14,190, carrying capacity of 3,810 and pin weight of 3,176 be too much for this TV?
Hope my pics show in the post:
4x4ord wrote:
Cummins had me figured but those weights do include 400 lbs of ballast in the front closet to offset some of the bike's weight:Click For Full-Size Image.
Click For Full-Size Image.4x4ord wrote:
I'm not overloaded with 16900 lbs hooked to my SRW.
Front truck axle 4980 lbs ..... empty weight is 4860
Rear truck axle 5820 lbs ..... empty weight is 3480
Trailer axles 14440 lbs ...... pin weight is 2460
Loaded truck weight is 10800 lbs ... the GVWR is 11500 lbs..... max rear axle weight rating is 7230 lbs
