BFL13's avatar
BFL13
Explorer II
Feb 26, 2015
ST Tire "Plies" Question and a PSI Question
(BTW I am aware of the various "issues" concerning Carlisles, Marathons, and ST vs LT, having read many tire threads here over the years. Moving right along then-- :)
My 2002 built OEM Goodyear Marathons (marked made in Canada) have just been replaced with Carlisles (marked made in China) built in 2014, and I have noted some differences in their "plies" as marked on the tires. Perhaps some of the experts here can explain it all. Thanks.
Both are ST225/75R15 "For Trailer service only" The Marathons are Load range C and the Carlisles are Load range D. They show the weight ratings 2150 at 50psi and 2540 at 65psi, so that is clear.
If it matters, here is another set of markings:
Marathons- C11L DOT PDHH MROR 2602
Carlisles- AQ29 DOT AQHH 2114
Now the plies as marked on the tires:
Marathons- Tread 5 plies 2 Poly cord + 2 steel cord + 1 nylon cord
Sidewall 2 plies poly cord
Carlisle RH- Tread 4 plies 2 poly + 2 steel Sidewall 2 plies poly
In the recent thread about Carlisle RHs ISTR it was posted that they have a nylon cap or whatever, unlike the older Carlisles, but I am unclear on that. If they have nylon now, why isn't that marked like on the Marathons?
Here is the Carlisle blurb on that. Mine are the Duratrail technology Radial Trail RH
http://www.carlisletransportationproducts.com/product/tires/trailers-toy-haulers-towables
OK different topic, but I don't want two threads. For weight carrying, I only need Cs at 50 PSI, but now I have these Ds carrying the same weights. I know my truck tires have "adjustable" PSIs based on the load they carry up to a max rating.
What about the STs? Do I pump the Ds to 65 or go with something less since they will not be "loaded" fully? Thanks.
