CKNSLS
Feb 27, 2015Explorer
Me Again wrote:CKNSLS wrote:
You can search for that info if you want it bad enough.
Well in fairness I think you should be more forthright. I suspect your trailer is small and light enough that just about any tire would be fine.
Did you have a history of failure that was cured by the switch to the Radial HD?
You also repeatedly state in other threads that you only to at 60 mph which would greatly decrease tire problems for many.
Speed, weight, and capacity are all inter related. I suspect that you would do fine with even Blow Max tires.
So we await more details from you besides blind cheerleadering without a better reference point. This is the 5th section where many have larger and heavier trailers.
I actually use the product. I am not a weekend to the lake tower. I have over 10000 miles on the tires.
About Fifth Wheel Group
