ilvtravln
Oct 05, 2019Explorer II
ST Tires ???
Have LT tires on my fiver, thinking of going back to ST tires, does anyone have a brand they would recommend. Not to keen on Chinese tires. Size is ST 235 85 16. Thanks
ilvtravln wrote:I can only rely on what I've seen when comparing ST tires to tires I replaced them with, which at that time were LT tires. The ST tires I took off, Carlisle ST 235/85-16, had such flimsy sidewalls that, with it dismounted from the wheel, you could basically collapse the tire by simply sitting on it.fj12ryder wrote:
Just curious why you would go back to ST tires. Have you had issues with the LT tires you've been using? Personally the only ST tire I would ever buy would be a Sailun.
I have Michelin Ribs, no problems, but the ST tires have a thicker sidewall so that is why I am considering them. Axles are 6K.
