ilvtravln
Oct 05, 2019Explorer II
ST Tires ???
Have LT tires on my fiver, thinking of going back to ST tires, does anyone have a brand they would recommend. Not to keen on Chinese tires. Size is ST 235 85 16. Thanks
fj12ryder wrote:ilvtravln wrote:I can only rely on what I've seen when comparing ST tires to tires I replaced them with, which at that time were LT tires. The ST tires I took off, Carlisle ST 235/85-16, had such flimsy sidewalls that, with it dismounted from the wheel, you could basically collapse the tire by simply sitting on it.fj12ryder wrote:
Just curious why you would go back to ST tires. Have you had issues with the LT tires you've been using? Personally the only ST tire I would ever buy would be a Sailun.
I have Michelin Ribs, no problems, but the ST tires have a thicker sidewall so that is why I am considering them. Axles are 6K.
One of the boasts that you seem to hear is that ST tires have stronger sidewalls, but that hasn't been borne out by what I've seen.
And if you've had good luck with LT tires, why change? You know the old saying: "If it ain't broke, don't fix it". I would stick with a known quantity. JMO of course.
