First off.......
Remove those slide out supports. Slide outs are 'self supporting' and do NOT need supports under them.
Those aftermarket items can cause damage to slide out from the upward pressure especially should RV settle.
They are just a means of getting your RV Monies.
If needed the RV MFG. would have included them with the rig.
And if you think this is just my opinion..check with your RV MFG. about their use
As for stabilizing the rig..
Adding an aftermarket item that DOES help is JT Strong Arms or any other brand.
They are criss-cross supports that go from front landing gear to frame and rear stabilizers to frame.
They remove that side to side sway
X-Chocks between tires both sides ....they help remove that for/aft motion
And one thing I do to make rig more solid:
After rig is leveled side to side and getting ready to unhook truck I run landing gear down several inches THEN drop inner leg and pin them
Less inner leg used---less wobble
I run landing gear until rig is level front to rear
Lower front landing gear 1" below level
Run rear stabilizers down TIGHT
Then run front landing gear back up the 1" to level
Still will have a 'little' motion due to tires/suspension
But you can also place a couple of bottle jacks under frame by wheels to minimize/stop that motion
