camp-n-family wrote:
JT Strongarms! Best mod I've done. Not the cheapest, there are other brands of the same idea, but worth every penny imho. With 2 kids the trailer would shake so bad that several of the bolt heads on the stabilizer jacks broke. Installed the strongarms and any movement is gone.
Jacks only stabilize in one direction, parallel to how they are mounted, and even then they weaken as the jacks extend. The strongarms brace them in the perpendicular and parallel planes.
x1,000!!
I finished install just after we finished a stint as Park Host, even with a pin tripod, 5er wiggled a fare amount.
Well took it out Thanksgiving weekend to Old Stone Village, a couple of dinners, and some wine tasting.
Well set the JT'S and left the pin tripod in the truck.
WOW!!
What a difference, almost zero wiggle, not sure if I set them correctly, but major difference.
Now the interesting part, my landing gear legs are about 59" apart, well the kit for the 58" or less is on sale for $184.88 on line at Camping World. Well an inch could not make that much difference, so ordered. They fit like a glove. I also found the difference between this kit and the one for greater than 58" is an additional backing plate. One could likely order from Lippert, or make one.
I did have an issue with the swing bolts, the top of the bolt should be flat, the ones that came with the kit were slightly rounded, this prevented the arms from swinging correctly, Lippert CS did well, first time sent the same wrong bolts, second time once I explained the issue, they got the correct bolts as all of their inventory was wrong.
Here is a link to the ones on sale.
JT Strong Arms for $184.88
