csamayfield55 wrote:
Do some research on JT strong arm. Best way hands down to take the shake out of a trailer without a leveling system
Chris
I finished our install, but haven't had the rig out since install, can't weight to test.
Well if your front jack are near 58" between them this is a great deal
at $185 for the set!. As I understand the only difference between the 58" set and the wider set is the wider set has two extra backing plates and an extra bolt, so the front arms can be separated more than 1-1/2".
JT Strong arms
