Vulcaneer
Apr 26, 2014Explorer
Why all the discussion? Just avoid using Stainless lug nuts, Like the OP advises. Makes sense to me.
And I happen to agree with him. Dis-similar metals are usually a problem in these types of torquing applications.
Anti Seize will tend to promote bolt/stud stretching due to added lubricity. Usually if a bolt stretches, it will not come up to torque. But sometimes the nut will come up to torque spec. But the bolt can fatigue over time, and THEN the bolt can stretch, without warning. That is until your studs break or the nuts loosen or fall off as you go down the road.
Personally I don't use it on smaller lug studs. Figure if a lug nut gets rusted on, I would rather break the stud and replace it with new. A little bit of a chore. But not that hard, really.
About Fifth Wheel Group
