fj12ryder
Apr 26, 2014Explorer III
I've read of absolutely no instances of nuts/bolts unscrewing because of the use of anti-seize. We used it at the plant where I worked for 40 years, and I've used it on lug nuts for another 30 years. I also read a couple studies that stated that anti-seize will not cause a problem with the friction holding properties of a bolt when it is limited to the threads.
From what I've read they seem to recommend about 10% less torque with anti-seize than with a dry bolt. That equates to about 8-10 ft.lbs. on a car wheel. Consider the fact that most people don't even use a torque wrench when tightening their lug nuts. It's very unlikely that those lug nuts get tightened to spec when someone changes a tire, so a 10% change in torque specs really are pretty minimal. I mean my wheels on my toyhauler call for 100-110 ft.lbs. That's the difference between lubed studs and non-lubed. So it really comes down to a non-issue.
Okay, I'm done. LOL
Okay, I'm done. LOL
About Fifth Wheel Group
