Michelle_S
Apr 10, 2021Explorer III
Here is the Keystone Memo:
MEMORANDUM
To: All Keystone Dealers
Date: March 1, 2021
Re: WARRANTY COVERAGE RELATED TO DAMAGE
CAUSED BY GOOSE NECK ADAPTERS
As you all know, Keystone fifth wheels come equipped with a pin box system designed to be used with a
conventional fifth wheel hitch system. Sometimes customers use goose neck adapters with the
conventional systems. Before Keystone would consider covering under its limited warranty any damage
to a fifth wheel caused by or associated with a goose neck adapter, the adapter would need to have
been approved by Keystone. Otherwise, the “unauthorized” attachment, in this case the goose neck
adapter, would cause an exclusion from warranty coverage.
There are various brands of goose neck adapters in the industry, none of which have ever been
“authorized” or “approved for use” by Keystone, except for the Reese Goose Box and the Anderson
Ultimate 5th Wheel Connection Goose Neck Adapter. Over the past couple of years we have noticed an
increase in the number of frame failures and sidewall damage on fifth wheels that use the Anderson
Goose Neck Adapter.
Lippert Components is the leading frame supplier in the RV Industry and has the expertise to evaluate
the use of goose neck adapters and the effect of their use on a fifth wheel. We approached LCI and
were informed that it has not, and it will not, honor or pay any warranty claims for damage to the front
end frame/structure or any parts or components of any fifth wheel, when a fifth wheel is being used
with any goose neck adapter, with the exception of the “Reese Goose Box” (having gone through
extensive suitability testing by Reese and LCI). LCI informed us that this policy and warranty exclusion,
except for the Reese Goose Box, applies to all brand fifth wheels currently being sold the in RV
Industry today, not just Keystone.
In light of the position being taken by LCI with all fifth wheel brands in the industry and Keystone’s
further evaluation of the effects of a goose neck adapter on a fifth wheel, Anderson Goose Neck
Adapters are no longer authorized or approved for use on Keystone, Dutchmen or CrossRoads products.
This decision is not a commentary or negative statement regarding the Anderson brand or the quality of
the brand. And, this does not mean that an Anderson Goose Neck Adapter cannot be used with a
Keystone product. Rather, we are simply stating that if Anderson Adapter is used by a customer with a
Keystone fifth wheel and later damage or loss occurs to the fifth wheel as a result of using the Anderson
Adapter, Keystone will not warrant the same or cover the cost of any such damage or loss.
We want to give you some runway to adjust to our updated policy on Anderson Goose Neck Adapters.
Therefore, should a dealer/customer encounter a failure on any Keystone, Dutchmen or CrossRoads
product which is thought to be affected by the use of the Anderson Ultimate 5th Wheel Connection
Goose Neck Adapters installed prior to March 15, 2021, follow the normal process to receive warranty
consideration for those claims.
Any Anderson Goose Neck Adapters installed after March 15, 2021, will not be eligible for warranty
consideration. Proof of the date of the Anderson installation will be required as part of any claim
submission.
For additional assistance, contact a Customer Service team:
Luxury (LX)
Toy Haulers
(TH)
Premium
(PR)
Light Weight
(LW)
Traditional
(TR)
Dutchmen
(DM)
CrossRoads
(CR)
Alpine Fuzion/Impact Cougar Bullet Hideout Aerolite Cameo
Arcadia Raptor/Carbon Sprinter Outback Residence Aspen Trail Cruiser
Avalanche Rubicon Passport Retreat Atlas Hampton
Laredo Voltage/Endurance Springdale Coleman Redwood
Montana Yukon Summerland Denali Sunset Trail
HC Montana Kodiak Volante
Zinger
MEMORANDUM
Date: March 1, 2021
Goose Neck Adapter.
submission.
Luxury (LX)
Toy Haulers
(TH)
Premium
(PR)
Light Weight
(LW)
Traditional
(TR)
Dutchmen
(DM)
CrossRoads
(CR)
Zinger
About Fifth Wheel Group
19,043 PostsLatest Activity: Aug 23, 2026
