GrumpyandGrandm
Sep 06, 2014Explorer
rsbabson wrote:
. So you cant load the fridge up and roll down the road with your groceries?
Yes you can.
The FW using residentials will run while on the road since the inverter will be powered by the alterntator in the tow vehicle the same way it charges the battery in the FW. The residentials that are being used only draw 6.9 amps so the 100 amp inverter being used will run for a good while. With that said they are not made for boondocking, but for the "snowbirds" or full timers.
EDIT: Spoke too soon, looked at my notes after my post and as PCM1959 said it is only a 3 amp draw. Sorry for the error.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 25, 2026
