ol_Bombero-JC
Sep 07, 2014Explorer
pcm1959 wrote:
Chris, ORDER THE RESIDENTIAL refrig! You won't regret it. We are pretty much the same type of campers as you.
I ordered a 2014 Lifestyle LS36fw with an optional Norcold 1210 side/side refrig which was a $2800 option. I took delivery of the rig in early March. The Norcold has been nothing but trouble. I should have saved my money! But that is all another story. I pulled-out the Norcold and sold it on CList for $1750. That paid for a 1000 pure sine wave inverter, transfer switch, cables, a Samsung RF197 French door refridge and anything else I needed to do the mod. I already had 2 deep cycle 6 volt batteries. So I just added an inverter with a dedicated line to the refrige with the transfer switch.
I don't know what model refrig you will be getting but the Samsung draws 3 amps upon compressor start-up and about 1 amp while running otherwise. The inverter has a 1.4 amp no load draw.
We live in FL and it will take about 3.5 hours to cool down from the mid 90's to -2/37 degrees!!! Starting out with full batteries they are drawn down to about 2/3 to 1/2 in that time. Once hitched up the truck prevents any further draw. If you keep the doors closed, it will stay at safe temp for hours during travel IF you don't want to run the inverter. We leave the inverter on without issue. you could always add 2 more batteries or a solar panel if your reserve battery power concerned you. If is not a problem for us.
Ours has the ice maker but no filtered water. That is fine as we don't use a lot of ice and filter all the water coming into our rig. We are not big ice users either but make ice in the old-fashioned ice trays. We have five of them and we just dump the ice from them in freezer ice bin and use a scoop when ice is needed. Like you, we are not full timers and didn't want the stale water setting in the lines between trips nor the worry of winterizing.
We LOVE the latest mod and feel such freedom from the NO-Cold. I can't imagine you'd regret going the residential route. Good luck. Phillip
Residential should be an easy decision! (as in "no-brainer")..:W
*SAFE*,, reliable - and easy options for power.
Try a search on residential refrigerators in the Motor Home forums.
There are still some AC/Propane lovers - but they are getting to be few and far-between.
The quality -and longevity- of AC/propane is *NOT* what it used to be - a guess would be due to inferior Chinese components.
The proof of that is the replacement of the above with the Amish cooling units - which (IMO) is still throwing money at something that should be scrapped ASAP when it fails. (and it will)..:(
BTW - in re: "Safe".
Anyone with a new or old AC/Propane refrigerator should have a fusible link activated extinguisher in the rear of the freezer compartment.
The life (and RV) you save - may be your own..;)
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
