John___Angela
Sep 07, 2014Explorer
CA Traveler wrote:John & Angela wrote:It depends upon the actual model which the poster did not specify. One model of the previously mentioned Samsung RF197 indicated it draws 15A at 120V which may well include the worse case scenario. But I gave the poster the formulas he can use for his application.CA Traveler wrote:rsbabson wrote:Never is that a good idea. The contents will warm up before they cool down in the warm refer and that is asking for bacteria problems.
Im looking to buy a Columbus 320rs with the residental fridge also. So you cant load the fridge up and roll down the road with your groceries?
Using a 300W refer draw for example you would need to supply 300W/12V = 25A so use 30A to allow for losses including the inverter. Your alternator may/may not have that extra capacity. Typically a truck and trailer wiring will not have the capacity to carry that amperage without significant voltage loss. One option is to have an inverter in the truck and run a 120V line back to the refer.
Almost any option includes a precooled refer. This also allows the refer to cycle on/off which reduces the overall power over a period of time. Plus once cooled you may be able to turn it off for a period of time while driving.
Your power usage estimate is off. Typically they draw about 1 amp at 120 volts. They will run for about 5 to 7 minutes and then cycle off for 10 to 12 minutes. No problem for an alternator in a truck. I agree with earlier comment insuring that the charge line to the trailer be of sufficient gauge. The running lights on the trailer will draw as much or more than the fridge.
Refers do cycle on and off which certainly helps reduce power. But this poster wanted to start with a warm refer which won't cycle until it cools. However I certainly hope no one does that as bacteria develop quickly with warm food.
You make a good point re the cool down. Ours seems to do it in an initial 15 to 20 minute cycle followed by a little 5 minute break and then on for 10 to 15 more and it's cool. I would imagine that 15 amp thing that you saw referred to start up current for the first 1/2 second which is irrelevant to the overall power budget. Most draw 1 to 1.3 amps when cycled on. This translates to around 10 amps DC. Our Samlex inverter actually reports in watts and it is usually between 95 and 110 watts of power. Not even a grunt for an alternator. Ours is a 22 cubic foot frigidaire. We have an older flat screen TV in the rig. It uses about the same....except its duty cycle is 100 percent...when its on of course.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
